MrWizard
Oct 13, 2015Moderator
Sound Guy
you define safe.. as safe to use suppressor ..AS no damage to the suppressor will occur
the OP wants to install in between all power and the breaker box and leave it there
that is NOT what PI says
they have given all the info and description of use, that they intend too
so He can do it their way, or he can take his chances
you want them to define it further, which it is clear, they are not going to do
they sell a bypass switch, if you or the OP, gets the switch
you do not have to worry about the install, Provided you use the switch
you want them to OK a permanent install for all power choices
it is clear they will not
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
