MrWizard
Oct 13, 2015Moderator
that is NOT what I said, and you know it
you are arguing semantics of wording
what i said was you can't do what you want and get a guarantee whether its safe for the EMS or that it will or will not work statement from PI, which is what you want them to define
i said if you do this you take your chances, because PI won't vouch for it
i also said it should be OK with a generator, but PI was not going to say so
and i said it isn't needed
you want to observe it.. OK,,thats what you want
but a generator is not going produce thousands of volts spike from lighting, it is not going to drop to 100v and state there under heavy load, it will shut down if it can't carry the load and sustain voltage, unless something is terribly out of whack and that is also going to show up under light load
the Hondas, yammys, and champions, and onans are simply not going to do that kind of malfunction and not be noticed
you Want constant view of the genset power from the EMS
but is NOT needed
its just something you want
PI is not saying OK to what you want, and you want to debate that with me.
you have your solution, I think you are on safe ground as far as operation
that doesn't mean i think PI should offer a declaration of such a practice
but is NOT needed
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
