NinerBikes
Jan 14, 2015Explorer
smkettner wrote:
The BMS will cut power before the damage occurs. I believe the BMS will allow 100% DoD based on capacity and staying above that minimum voltage. Voltage will get into that curve toward the bottom but the cut-off is complete as the contactor opens. Not the same as a brown out as your 12v flooded battery goes below 11 volts.
The best part is you can keep your solar producing max all day as the lithium battery does not taper charging anything like the flooded battery. And no need to ever get to 100% to preserve battery life. Yes bouncing in the middle 80% of capacity is best for longevity on a lithium battery.
Would bouncing around in the middle 80% be true also for smart phone batteries?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
