eric1514
Dec 20, 2014Explorer
enblethen wrote:
You said it died. Did the engine shut down and the lights on the instrument panel come on or did it shut down with no lights?
No instrument lights would indicate failure between the battery and the fuse block.
Lights would indicate issue in the ignition system
The engine stopped and all the lights on the dash came on. I turned the key off, waited 5 seconds then restarted the engine all dash lights were normal, no "check engine" light or any other abnormalities.
@MrWizard-The tripped auto reset makes sense, if such a reset exists that would shut off the engine and reset in less than 10 secs. I'll look for something like that.
I do think the blinkers and stalling are coincidental. I can't say for sure they both failed at the same time but I do know the engine reset quickly, but the blinkers took overnight to come back.
