bigorange
May 29, 2018Explorer
boogie_4wheel wrote:
Open the cover and try it. Mine did the same thing. I drilled a few holes along the lower-left of the cover. Problem solved.
While it isn't right, it worked. I visited a local parts and repair shop one the issue and two guys said that it was a 'common' problem on the suburban.
While on the road I had learned that it consistently worked fine with the door open, but it was a 50/50 with it closed. I had cut and bent the bottom corner to allow more fresh air in, and then replaced with a new cover and added the holes for a cleaner look after the trip.
Interesting...I had opened the cover to see if any obvious issue, but hadn't tried it with the door open.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
