bigorange
May 29, 2018Explorer
wrgrs50s wrote:
If you shut off your propane bottles, then turn them on when you get to the campsite, the slight pressure loss can cause a pocket to make the gas valve hesitate causing irregular pressure. Once the line is fully pressurized then the valve will provide continuous operation. Most time a quick light of a stovetop burner will allow the pressure pocket or air gap to pass and then you will have full pressure to the gas valve at the water heater. Try this next time, or before going to a dealer.
I always prime the propane lines before a trip by lighting the stove, and when I noticed this issue we'd already been using the stove, refrigerator, and water heater (hadn't noticed this issue before, but may have been happening) on propane for a couple days so I'm pretty sure there was no air in the propane lines.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
