GASMAN6674
May 30, 2018Explorer
The whoosh you describe is delayed ignition. Gas is accumulating then finally lights. If you don't want to go back to the dealer then check the manual and verify position of the igniter, it is probably too far away from the burner. Adjust as needed. Good luck
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
