bigorange's avatar
bigorange
Erratic water heater lighting
Suburban water heater SW6DE experiencing erratic issues lighting. New trailer on our 2nd trip, but not sure if it's a new issue since I possibly just didn't notice it on our 1st trip. Click-click-click then a loud whoosh sound like a large pocket of propane lighting up, but water heater doesn't light, then click-click-click nothing or maybe lights as it should. Seems to take a few tries to light successfully.
Once it finally lights it seems to work fine, but the loud whoosh and even seeing the door on the outside of the heater move from the propane flare up is very concerning. At first I thought it might be due to high winds, but the same thing happened other times with no winds.
Will take it to the dealer to check it out under warranty, but hoping maybe something obvious that I'm missing.
  • boogie_4wheel wrote:
    Open the cover and try it. Mine did the same thing. I drilled a few holes along the lower-left of the cover. Problem solved.
    While it isn't right, it worked. I visited a local parts and repair shop one the issue and two guys said that it was a 'common' problem on the suburban.
    While on the road I had learned that it consistently worked fine with the door open, but it was a 50/50 with it closed. I had cut and bent the bottom corner to allow more fresh air in, and then replaced with a new cover and added the holes for a cleaner look after the trip.
    Interesting...I had opened the cover to see if any obvious issue, but hadn't tried it with the door open.
  • If you shut off your propane bottles, then turn them on when you get to the campsite, the slight pressure loss can cause a pocket to make the gas valve hesitate causing irregular pressure. Once the line is fully pressurized then the valve will provide continuous operation. Most time a quick light of a stovetop burner will allow the pressure pocket or air gap to pass and then you will have full pressure to the gas valve at the water heater. Try this next time, or before going to a dealer.
  • Open the cover and try it. Mine did the same thing. I drilled a few holes along the lower-left of the cover. Problem solved.
  • just me ,I would not fool with it ,and I,d stop using it. you could start a fire. take it back to your dealer. but theres things that the people in the know might chime in to help you out.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
