Adam-12
May 27, 2013Explorer
HiTech wrote:
Adam when I was in the car business we were modifying fuel lines to handle ethanol in the 80's and 90s. Cars have been designed to run well with E10 for over two decades now. Yes you do get worse fuel economy. Yes, if you have a high compression engine or forced induction, you will get More horsepower as well.
It's generally worse fuel than pure gas. But it's not that modern engines and fuel systems have any special problem with it.
Jim
I agree with you Jim. However, modifying the older engines, still doesn't solve the greater water accumulation caused by alcohol which then sits in the float bowl of a generator during storage.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
