naturist
Jul 12, 2015Nomad II
one of the reasons for exercising any generator is to make sure that oil gets on the cylinder walls, bearings, and piston rings so they don't rust, so regardless of the fuel used, you want to run the generator from time to time to prevent rust. In fact, let it sit idle long enough, the engine will seize up and be impossible to turn over, let alone start.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
