77rollalong
Jun 08, 2018Explorer
I just did both of ours on our 460, the only thing i had to heat up to get off was the manifold to the cross-over pipe, everything else came off easy considering its a 1977. and did not need to jack it up at all, was enough room to slide under to remove the nuts for the cross over pipe. Ours also did have a gasket in there as well, and just dressed up the manifold face with the belt sander
view on right side without the dog house, the two front bolts you can get from under the hood, the other 6 from inside
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
