Sounds like the surface was not cleaned well if the caulk is missing. I would start with removing all the loose caulk and cleaning the surface good with acetone then use Geocel as posted above it has more of an adhesive property the the Dicor or other caulks that I have tried. It dries firmer and does not crack.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
