wa8yxm
Jul 28, 2020Explorer III
dryfly wrote:
If it were me, I would get a compression type coax fitting, the type that goes on the end of the coaxial cable (male F compression for RG-59 cable)and fill the end where the coax goes into the fitting with epoxy to seal it.
You then have a nice waterproof screw on fitting that will keep dirt out of the female connector and protect the threads and they are cheap.
Same here. only two "Edits"
1: Compression ring units come in standard and "Weatherproof" Get weatherproof
2: I use Goop instead of expoxy But that's just becasue I use a lot of Goop general purpose adheasive/sealant that's way easier to work with.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
