dspencer
Apr 08, 2014Explorer
rk911 wrote:dspencer wrote:
First of all my knowledge of electricity is very little. :h The DW and i just bought a new left over 2013 Gray Wolf 26BH about 6 weeks ago. Sunday i was working around the trailer getting ready to go on our firt outting with it next weekend. I went to plug something into the outside power outlet and it's dead. I checked all the fuses and breakers and everything is okay. Also i might add that all the other outlets work in the camper except this one exterior outlet right beside the front door. Anything i might have missed would be appreciated.
I'll bet you have a GFCI outlet in one of the storage bays that has tripped. check carefully. many times a GFCI outlet will be wired with other outlets. if the GFCI trips all other outlets downstream from there will be dead.
I thought about the GFI being tripped, i checked on the inside and nothing amiss there however I did not check for one in the 2 bays. I truthfully don't know if there is one in there or not but i will check. I also hadn't thought about being tied to one of the swithches. I have 2 exterior lights and one switch that controls 2 lights as you walk in the door. I will check these 2 things.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
