westend
Apr 28, 2017Explorer
I'd suggest to try just the tanks and piping you have before going to any heroic measures.
I used to regularly fish on ice with just a conventional 20 lb cylinder and a rubber hose that ran to the inside of the fish house. Never had a freeze up problem. A larger cylinder (100 lbs.) will definitely eliminate any freeze problems, especially if there is no water inside the regulator or lines.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
