wa8yxm
Apr 28, 2017Explorer III
What can be done is to make sure they are full of PROPANE not BUTANE
Why:
Vapor temp of PROPANE is roughly -40 (39.something as I recall) at any temp over -30 you will have enough pressure for everything to work.. at -40, it will not.
NOTE; at -40 it don't matter if you are using "C" or "F". same temp.
Butane however the vapor point is right around the freezing point of water. So if it's freezing out, it don't work
SOME stores.. Epically here where I am in the "Sunny South" lie to you and sell the cheaper Butane at Propane prices.. Butane gives slightly more heat per unit volume so nobody comnplains.. But if you get cold. it don't work.
Why:
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
