js6343js6343's avatar
js6343js6343
EZ Lube/Ultra Lube
I am familiar with many of the posts discussing the pros and cons of EZ Lube. The case for regular hand packing and inspection makes sense and is a compelling one. So I am not wanting to open that debate up here again.
But my question is for those who USE EZ Lube and do not regularly hand pack bearings. What is your ACTUAL EXPERIENCE with that approach? Has anyone here actually had grease leak back through the seals into the brakes? If so, how did that manifest itself. How did you find out. Has anyone experienced any other failures using the EZ Lube method?
Has anyone had good success with the EZ Lube method? No issues, etc. Just looking for real world results from FOLKS WHO USE EZ Lube regularly. Right or wrong I am leaning towards use of EZ Lube for annual greasing and full inspection every 3 to five years.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
