billyboyExplorerOct 24, 2015f53 starter solenoidi just replaced my starter solenoid for the third time in 6 1/2 years, anyone else had this problem. it just sticks and i have to bang on it to get it to work.
MEXICOWANDERERExplorerOct 24, 2015Remove starter then remove solenoidGrab plunger and move it back and forthThe slightest catch while moving it can provoke problemsGrab toothed drive gear and try to wiggle it crosswise to the shaftDoes it wiggle?The slightest bind can hang the drive gear in the ring gearStill nothing? Remove end plate and disassemble starter motor from drive housingLook st starter drive pivot fork. If the round tangs on the bottom are flattened a lot or if one tang is worn more than the other, replace the forkNo joy so far? Check the plunger for burrs. Then shine the plunger until it looks like it was chrome platedSpray silicone LUBE on the plunger and on the shift fork pivot.Hope this helps
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentF53 starter solenoidSOLVED: Location of Starter Solenoid Switch: 2006 F53Starter SolenoideStarter Solenoid Location96 f53 starter problem
