i just replaced my starter solenoid for the third time in 6 1/2 years, anyone else had this problem. it just sticks and i have to bang on it to get it to work.
I asssssssssumed you had already checked for bad battery connections and a greedy starter. Low voltage will either weld or crispy critter the bolt and disc contact as will a dragging starter motor. What is the voltage at the copper STUD on the solenoid as you are cranking the engine?
This cannot be guesswork. You actually have to do it. It's like getting a root canal - awful ut the altetnative is much worse.
