jwmII
Nov 19, 2015Explorer
j-d wrote:
Has to come out of it's "pocket" but I've thought I could do the actual cooling unit swap right inside the coach. Haven't tested that idea, though. RV fridge is more bulky than heavy. I looked up the weight and it said 142 for the N841 I found. It'd be lighter without doors and a couple of the shelves. I'd take the doors off to do the cooling unit to be able to get inside, and reduce possible damage.
Right, Slide it out on to a bench or stool that is as close as possible in height as the fridge location. After disconnecting everything slide it out of the compartment and get to work changing out the cooling unit in the coach. It's nice to have a helper so you don't have to keep moving from front to rear of the fridge while doing the change out. If you are doing it by yourself set the bench or stool on a throw rug or old blanket. This way if you are in a spot where you cannot go around the fridge while doing the change out you can just turn the whole thing around easily.
