pezvela's avatar
pezvela
Failure of Norcold N811LT fridge
This is a 2008 model that have been running almost continuously since 2008, except for 1-2 months in the summer when the trailer is not used. Used on 110v almost exclusively, unless a power outage auto-trips it over to propane.
Woke up this morning to find the "on" light flashing and NO COOLING. Would not operate on propane, either, would not even ignite.
This unit does have a thermal cutoff that is built into the flue. I bypassed this circuit and it began to heat back up in the flue AND the propane circuit immediately began working again.
But the flue gets VERY hot back there, on both elec and prop, and the fridge and freezer do not cool after 8 hours of continuous operation. Feeling the ammonia(?)coils in the back finds that only the portion immediately near the flame/heating element is getting warm. The rest of the coils are ambient temperature. Shouldn't these be warm to the touch?
All visible fuses are fine on the circuit board.
Any DIY suggestions on getting this fixed? I have turned it off due to my belief that the flue is getting much too hot.
  • When you say the "cooling unit" is bad, are you referring to the ammonia coils? If so, I assume that is un-replaceable?
  • Likely the cooling unit is bad. That thermal fuse is to keep the thing from catching fire- not a good idea to bypass safety stuff, unless you are there closely monitoring.
