NRALIFR
Jun 07, 2019Explorer
Regarding replacing the WFCO converter charger, just call Randy at Bestconverter.com and go with his recommendation. It will likely be a Progressive Dynamics Wildcat or a Boondocker. Both brands have upgrade kits made specifically for your WFCO, and will be about as easy as you can get. You don’t need any bigger than what you have now.
I think you meant to say “inverter generator” rather than inverter. Two different things. If you don’t intend to run your air conditioning from the generator, then you could even go with a 1000 watt model. It would have plenty of capacity, as long as you manage what’s using it along with the converter charger. A generator this size is also smaller and lighter, so they are easier to deal with. That’s what I use for our power needs 99% of the time.
I personally don’t like the idea of depending on a generator to run the AC, because that typically means you’re going to need a bigger generator, and you’ll want to run it a lot more than for charging a battery, and at a higher load on the generator, so it will be making more noise and consuming more fuel.
