valhalla360
Jun 07, 2019Navigator
SoonerWing03 wrote:
***disclaimer*** reading most of these power related threads is like reading something where 50% of it is in a language I don’t speak/read/understand.
I am planning a 10 - 12 day family summer vacation to the Yellowstone Grand Teton area and it looks like we might need to do a fair amount of boondocking.... which is fine by me but we have yet to do. We will do some practice runs around home first but my question is more about which or what size power converter I should upgrade to.
My rig currently has the WFCO WF-8955PEC which I understand is not a great converter. I just removed a single Marine style 12V battery in favor of two 6V G2 Golf Cart batteries. My understanding is that is an upgrade but a good example of how good of a grasp on this is that I was shocked when I got to Sams to purchase said 6V batteries and to my surprise they were roughly the same size as the 12V :h I was expecting them to be roughly half the size because well 6 is half of 12.... so that is what you are dealing with here.
I am looking to pick up an inverter for the camper (2017 MPG 2400BH) trip and wondering if a 3500 watt (like a Predator or Champion) watt would be sufficient or could I even get by with a 2000? Additionally, what converter should I consider?
Big question: What do you plan to run when off the grid and how long?
Odds are the charging unit (converter) isn't a big issue worth addressing right now.
Do you plan to run air/con off grid? If yes, that means the generator will be running and charging isn't a major consideration. This is typically the turning point between operating off battery power vs running the generator.
If you are just running a few lights and maybe the TV off battery, you batteries should get you at least a couple days and then an hour or two running the generator (which powers the battery charger) should keep you going.
