time2roll
Nov 03, 2019Nomad
hedgehopper wrote:Utility power or sweat it out.NRALIFR wrote:Then how do you run the AC?
I personally don’t like the idea of depending on a generator to run the AC, because that typically means you’re going to need a bigger generator, and you’ll want to run it a lot more than for charging a battery, and at a higher load on the generator, so it will be making more noise and consuming more fuel.
