- lotto38ExplorerI purchased a water pump, wired it into the exisitn pump(fused of course) added a filter and some 1/2ID tubing. Put one end in jug and other in water inlet. SWEEEET. TUrn on pump and viola. No more lifitng heavy jugs of water
- 2oldmanExplorer II
pnichols wrote:
Without lifting!
I think the OP is talking about ... getting more water into the main tank from smaller reserve water tanks
Lifing water jugs will either get you into the best shape of your life or make you use way less water. - LynnmorExplorer II
pnichols wrote:
I think the OP is talking about camping somewhere out in the boondocks a long way from water and getting more water into the main tank from smaller reserve water tanks that they carry along ... a whole different story than being around faucets.
I like the idea of using the water pump already in the RV and it's built-in winterizing pickup hose to pump water into the main system from reserve water tanks. Clean and simple using equipment already on board.
That's what I do. I ran my "anti-freeze" hose to a tee just inboard of the city water inlet. I then removed the check valve guts from the city water inlet. An inline check valve was then added after the tee in the original inlet line. Now I can attach a short water hose to the city water inlet and place the other end in a container of water and pump it to the fresh water tank. No wiring, no dirty anti-freeze hose, and no expensive parts to buy.
pump - pnicholsExplorer III think the OP is talking about camping somewhere out in the boondocks a long way from water and getting more water into the main tank from smaller reserve water tanks that they carry along ... a whole different story than being around faucets.
I like the idea of using the water pump already in the RV and it's built-in winterizing pickup hose to pump water into the main system from reserve water tanks. Clean and simple using equipment already on board. - RJsfishinExplorerMan, these replies are making me tired !
Me, I drive to the the faucet, fill the water boy w/ 45 gals, drive back to the RV, poke the hose in the filler, flip a switch and go have a beer ! - RJsfishinExplorerDelete
- rockhillmanorExplorer IIA bilge pump, a portable jump start battery, and small inverter plug does the trick also.
Both inexpensive and IMHO no one should be on the road without the jump-it battery anyway! - RoyBExplorer IIII usualy find city water somewhere when back in the woods. The Natl Parks usually has a bathroom somewhere...
I carry a couple of 5-gallon fresh water totes and always have a folding two-wheel cart with me. If the water spigot isn't too far I just go get what I need and wheel it back.
Usually I am conscious of where fresh water is located and try to fill up my fresh water tank just before going in.. I always have my two 5-gallon tanks full when in travel mode... I have plenty of room on my 5x8 front deck on the trailer.
I use the folding two wheeled cart to haul off my waste water as well when camping off the grid...
I could probably improve on this alot...
Roy Ken - 2oldmanExplorer II
travelzoo wrote:
Sounds odd. I would think that would mean you'd use city water to either fill the tank or city water.
Just switch the valve to tank fill and draw your water from a container using the anti freeze hose and the RV water pump. - GjacExplorer III
travelzoo wrote:
I have a valve for water fill and city water but my water pump is under the closet floor in the bed room. Is this still possible? If so how would you do it?
If at your wet bay you have a valve for selecting city water or tank fill it's rather easy. Just switch the valve to tank fill and draw your water from a container using the anti freeze hose and the RV water pump. I'm sure all rigs are not setup this way, but check it out.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
