opnspaces
Aug 05, 2019Navigator III
allbrandauto wrote:
the ford 460 of this year had a map sensor that ran off engine vacuum maybe the hose is broken. also to set timing did you disconnect the timing connector to set timing
And equally important, did you reconnect the timing connector when finished setting the timing?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
