opnspaces
Aug 06, 2019Navigator III
If the cat is bolted on see if you can unbolt it and look through it. That vintage might be the old pellet type that you can't see through. But if it's the new honeycomb style it will be obvious if it's plugged or not.
While I would never recommend defeating emission components long term. If the cat is plugged you can probably knock the center out for a test.
If it's welded on you're going to have to go to an exhaust shop to have it cut out and inspected/replaced.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
