landyacht318
Sep 14, 2018Explorer
Amazing goop has a Marine version too. I've not tried it. Says it is UV resistant, which the regular version most definitely is NOT. They actually have several different versions.
Sanding with 80 grit for mechanical tooth is wise, but also wise to wipe with a solvent before using fresh new sandpaper and scuffing in a cross hatch pattern. No point in pushing containants into the sanding grooves
I have saturated light weight fiberglass cloth with Amazing Goop. thicker cloth does not saturate completely but still aids repairs, especially on those repairs needing to remain flexible.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
