Jethroish's avatar
Jethroish
Flipping Axle
Looking into having the axles flipped on my 30' gooseneck horse trailer. I need to raise the rear of the trailer 2 to 3 inches
Anyone done an axle flip and how much did it cost?
  • I found those flip kits too. Looks pretty simple.
    After posting this, I found something that may be better for my situation.
    Quick story...
    Got a new truck and had to adjust the gooseneck. It adjusts by 2.5 inches at a time. Moving one hole only gave me 4.5 to 5 inches of tail gate clearance. Moved it one more and got 7.5 inches of clearance. Problem now the trailer is more nose high than I am willing to have.
    Hopeful solution is, found that Reese makes a 1 inch extended collar drop in goose ball. Add that to the 7.5 inches then drop the gooseneck one hole. That "should" bring the nose of the trailer down by 1.5 inch and still leave me 6 inches of tail gate clearance.
    Looking at the springs and axles, I think a flip would work but going to try the "easy" fix first.
  • Thanks for the info on the Dexter flip kit. Just checked them out on Amazon. Both around $50 per axle kit. Available for 3" and 2&3/8" diameter axles. The smaller is the 3.5K axle and the larger is the 6-8K, per Etrailer. Towing my trailer is often a lot like the mid 1960's song, "Kind of a drag".
  • I did it myself in the driveway on a 30ft 5er. Dexter makes a flip kit for about $55 on Amazon. You do not need to weld the new saddles to the axle but it is better if you do. Just a couple of spot weld will do it once you are sure the saddles are in the right position.
    You will also need 4 jack stands or cribbing to hold the trailer up, a rolling floor jack helps but is not necessary, to position the axles, and watch a few youtube videos on the subject. Some of the lift methods are pretty interesting but not something I would try. One guy used cinder blocks on their side with a jack stand standing on the hollow portion of the block :E I just jacked it up and put the jack stands under the frame close to the spring shackles.
  • j-d's avatar
    j-d
    Explorer II
    azrving wrote:
    ...I would pull the trailer on to wood blocks until it is sitting level then measure the thickness of the blocks. That is the amount of lift you need...
    A measuring technique that's Beyond Clever! Load truck and trailer like they'll be for a trip, gather an assortment of boards, find a level area and measure the easy way!
  • The amount of lift will be determined by the diameter/radius of the axle plus the thickness of the spring pack and the perch. If you measure those parts and picture how moving them from above to below you will see how much lift you will get.
    Usually it's around 4 to 5 iches. I would pull the trailer on to wood blocks until it is sitting level then measure the thickness of the blocks. That is the amount of lift you need.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
