chuckbear wrote:
BFL13 wrote:
Since they are AGM's why do you have to float them at all if disconnected?
Even a new AGM can self discharge at about 3% per month. Older batteries, even more. The discharge rate is also temperature dependent. The higher the storage temp, the higher the discharge rate. Chuck
Storage in Saskabush from November to mid-March would be low discharge rate then.
Choice is float at maybe wrong voltage and undercharge or overcharge the whole time or some of the time doing one or the other with whatever bad consequences, or
Let each battery sit with no wires on it and take the hit from sitting undercharged by however much for how long, and then do an AGM type "recondition" in March.
I like the predictable outcome of disconnecting. Hate to be away and wonder if the solar is still working and how it is going. Plus the OP, who is not a battery newbie, would have confidence in being able to do the AGM recondition properly on his return
