BFL13's avatar
BFL13
Explorer II
Nov 29, 2020
Floating vs Storage Voltage Question
Moved this from another thread to open the topic generally. Question was if PD converters with the 13.2 storage voltage were compatible with floating voltage specs at 13.5 and above.
Many (all?) battery specs have the same floating voltages (2.25 a cell or so) My AGMs did and also the flooded batts I have had.
PD's are used successfully with all those other batteries according to various reports
Trojan eg, has 2.25 too, and says not to float either flooded or AGM at all if they will be charged frequently. ("cyclic use"?) So the PD's "storage" mode at only 13.2v is confusing. Is "storage" really "float" or something else?
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
Float is supposed to just make up for self-discharge so 13.5-13-8 typical seems high for that, unless it is GC2 6s?
Resting voltage of a full flooded is more like 12.8 so 13.2 is more above that. My ordinary AGMs spec resting at full was 13.0 though, and nobody said a PD is no good with AGMs.
Now I am not sure what "floating" vs "storage" is all about. Anybody explain? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,205 PostsLatest Activity: Feb 23, 2025
