I've been living in my coach in Georgia since July. Wednesday night, as most of the state was stuck in traffic, my water pump failed and dumped probably 25 gallons of fresh (thank goodness) water into...
The water pump and the fresh water tank are under the bed. The tank feeds the pump using gravity. The leak happened at the connection going into the pump. So technically it wasn't the pump that failed, it was the connection.
I think I have the wood dried. Luckily it's plywood and not MDF. My problem is getting the rest of the carpet out, o that I can replace it. Any thoughts on that?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
