Hello I went to check my camper the other day and found the laminate floor had a crack from the front of the camper to the back. The camper is stored outside on concrete pad and not been towed. It's a...
x2 on sheet vinyl, or you could use allure grip strip flooring at home depot. been there done that with vinyl stick squares. they don't work and will peel up
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
