Hello I went to check my camper the other day and found the laminate floor had a crack from the front of the camper to the back. The camper is stored outside on concrete pad and not been towed. It's a...
If the laminate is under the cabinets.Rent a toe kick saw and just cut along the cabinets. if you put sheet goods or planks down (which is easier door people) have to put quarter round down or some base to hide the height difference under the cabinets. Should be very easy to see if its under the cabinets though.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
