wa8yxm
Dec 09, 2013Explorer III
Benefits of LED lighting..
1: Lower current consumption, Florescent are better than Incandescent but LED's are better still.
2: Less likelyhood of breakage, and far easier to clean up if they break (I'm not so much worried about the tiny amount of mercury as I am the coated glass. that stuff is nasty)
3: A good LED assembly will outlast you.. Florcesent's a couple years if you are lucky.
An idea....
Friend of mine (Brought me my computer when I was in Hospital).. Replaced the florcesent tubes in one of his Thin-Light brand twin tube fixtures with a surface mount LED back up light assembly from a store in MI,Oh,KY called Meijer's.. I suspect Wally World will have it and if not auto______ (almost any store with AUTO in it's name)
Till he pointed it I could not tell the difference.
And there is room for TWO of those back up lights in that housing, That would give you the option of a HIGH/LOW light level.
Fnally, YES you can dim florcesents, not easy though
You canalso DIM led's Much easier.
An idea....
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
