AllegroD
Nov 15, 2017Nomad
Lantley wrote:time2roll wrote:
I read plenty of posts where 30 amp will run two air conditioners.
Try once and see. Watch your voltage, especially on the hot days.
In the end the correct answer is maybe?
The answer is maybe. It depends on the wiring. Are you coming off a CG line that is overloaded. If you try it, get a PI EMS which cuts your power if volts drop to 104 so you do not end up with heat damage on your AC or other electric items.
I like the idea posted earlier of, instead of adding another 30 amp, upgrade to an RV 50 Amp.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
