TheWanderer
Jul 06, 2019Explorer
Thanks! Yeah I did see the info on the rear seal crush, definitely going to have to research the specs for that.
I already ordered the high volume pump a while back, but you think that could cause issues? It looks exactly like the one that i took out.
I am not looking to have everything 100% perfect for this engine (nor do I have the time/money to do a full overhaul), just good enough to run for a couple years or so (fingers crossed)
Right now the plan is Oil pump, oil pan and gasket, main bearings, rod bearings, ensure the crank is in good order, timing chain, starter, gaskets and seals, and of course full fluids change in the process ( with Lucas additive for both the oil and transmission fluid.)
Also already changed the map sensor, pcv valve, purge valve solenoid, all spark plugs, and checked/replaced all the hoses.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
