RLS7201
Jul 07, 2019Explorer II
TheWanderer wrote:
I already ordered the high volume pump a while back, but you think that could cause issues? It looks exactly like the one that i took out.
If you intend to use that HV pump, double pin the distributor gear to the shaft. Or install a larger pin. It will shear with added load.
Go to the site I suggested and listen to the professional engine builders.
Richard
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
