TheWanderer's avatar
TheWanderer
Ford 460 engine questions/issues
Hey everyone, new to the forums and new to RV ownership. (Owned about 2 months now).
Firstly, HI! nice to join a community of like minded travelers!
I own a 26 foot 1988 ford gulfstream rv.
Ok so I am doing a fairly major overhaul on the Ford E350 v8 460 block engine. It has had a handful of things replaced already (starter, map sensor, pcv valve and tubing, spark plugs, etc etc.) and now I am working on lifting the engine to access the oil pump and crankshaft bearings. I just had a couple things I have run into I am unsure on.
Firstly, does anyone who has done work on this engine have any further tips for oil pan removal?? I have never had to go through so much just to get the dang oil pan off on a vehicle! The frame is 1 inch below the 7 inch deep oil pan. So in order to get the pan off and around the oil pump and crank and such, I have to lift the motor at least 5-6 inches. That meant removing a LOT including the throttle body, which leads me to my second question.
I cannot seem for the life of me to find a matching replacement for my bottom gasket for the throttle body, where it mounts to the engine. I will try and link a photo of it to show what mine looks like, but i cannot seem to find a replacement anywhere! It flaked some upon removal of the throttle body.
Thanks in advance for any advice or help!! I am quickly learning a LOT about this engine and RV with all the work i am doing. (I was basically scammed in purchasing a used RV. Tip for others/the future, GET SOMEONE TO INSPECT IT FIRST!)
Hope y'all have a great day, happy trails!
  • Yeah if I can't get good enough access to get the oil pan off and do the work, I will definitely bite the bullet and pull the engine. I already have a stand and hoist rental lined up if need be.
    I did have another question though I forgot to ask earlier. There is a ruber line I need to replace that runs from the purge valve solenoid in the PCV system down to these components that look almost like batteries?? (PCV runs to purge valve solonoid then splits to 2 lines, one runs to the intake I believe, one to these boxes through a hard line) Anyone happen to know what these components are for? Possibly part of the EGR system? I suppose I could dig through my electronic ford factory manuals and possibly find out, but if someone knows it would be much easier.
    I am by no means an expert mechanic but I have a fair amount of knowledge and experience. Still learning. :)
    Here is a photo of the boxes I refered to.
    Thanks again everyone!! :D
  • bite the bullet,, just pull the engine then you can do the hole thing,standing up. bench test ,then you,ll know its good.
  • One of the methods used to get the pan off of those rear sump fords is to drop the pan as far as possible and drop the oil pump. The tough part is removing the main bolt that holds the pick up tube.
    Richard
  • Summit Racing has lots of 460 parts. That mill is used in racing.
    I used copper exhaust gaskets from them.
    I converted to studs.
  • wnjj wrote:
    TheWanderer wrote:
    Thank you!!! I was just using the wrong term! Haha one more item off the list!
    Also, I reduced the photo size, hopefully that is small enough. :)
    Much appreciated!
    Looks great now. You’re welcome and good luck with the rest.
    If you don’t already use them, RockAuto is a fantastic place to buy parts.
    Agreed! I get virtually everything from either RockAuto, or Advanced Auto Parts with a 25% off online order coupon.
  • wnjj's avatar
    wnjj
    Explorer II
    Much appreciated!
  • Thank you!!! I was just using the wrong term! Haha one more item off the list!
    Much appreciated!
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
