enblethen
Jun 23, 2014Nomad
If you have no resistance then they are open.
Resistance check would be from the relay side of the fuse link to a clean exposed wire on the rig side.
Yes, they could be bad.
I would be nervous to see any type of melted insulation.
You checked the fuse links for voltage on the rig side?
There could be another wire dangling that has come completely into. Look real close! Look on relay terminal for a ring terminal that has no wire connected to it.
