myredracer's avatar
myredracer
Explorer II
Jun 14, 2018
Found small cut in roof membrane - should I be worried?
Was up on the roof cleaning it yesterday and found a thin slice in the membrane 2-3" long at rear. No idea when it happened and guessing last season. Maybe an overhanging branch in a CG? Had a cover on it all winter which I removed a couple of months ago.
No obvious swelled roof decking or signs of water leakage inside. Trusses are aluminum so at least won't rot. The cut is close to the rear wall which will have wood framing in it. Should I just repair it and hope there is no damage or insignificant damage and forget about it and carry on camping? I think the roof is plywood and not OSB which would help.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
