time2roll
Feb 11, 2014Nomad
I have a Frank's 30a superautomatic. If spending money today it would be PowerMaster then Hughes. But it would be about even.
Frank's has a 35 amp thermal fuse for protection and it seems to trip well before the 30a breaker on each side.
The superautomatic is supposed to cut power if too high or too low to boost. Fine but it has no reconnect delay. I have seen it rapidly connect/disconnect/reconnect in the right conditions.
Also seems to hang in low boost too long holding 126/128 volts when IMO 118 would be just fine.
Keep in mind the "70 amp" version only passes 35 amps per leg where 50 amp service is 50a each leg so you really may need the "100 amp" to be equivalent to Hughes. Considering my experience I am not sure you would even get the 35 amps per leg through the thing.
Mine is a few years old and still functions but have not used it in a while. Maybe it has improved since.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
