Gottahaveit's avatar
Gottahaveit
Moderator
Oct 15, 2015
Freezer icing up
Fridge and Freezer work great however, the freezer seems to be icing up. It's not over packed (lol the last few trips) and is set at 3 out of 5 settings. Fridge temp is at 35-40. Started happening a few months ago and we go a lot. Thanks.
  • Thanks all for your advise and recommendations. Will try the cotton, flashlight and dollar bill. Hope the cotton works as that would be a simple fix otherwise hope we can get another seal. BTW it is a Dometic but I won't know what model until we head over to storage in a few days. Thanks again, Kathie
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Bad Door seal if it's overly icing also it ices up more the less that is in it.
    Every time you open door moist air enteres, the moisture condenses out and freezes,, On your Home Sticks and bricks type residential fridge there is a heater believe it or not which melts that ice and a tube that lets it drain down to the fridge and from there out onto an evaporation tray.
    But on the RV absorption cooling unit there is no heater to do that (there is a heater but just around the door seal to prevent moisture there)
    (oh and one in the ice maker).
    Solution is to check the door seal. if it's good. DEFROST from time to time.
  • Set a flashlight in the freezer at night and turn off the room lights.... Look around the door Seal and look for light bleeding out.... That will be the bad spot in your door seal.....
  • stickdog wrote:
    Bad seal.
    YEP..freezer door seal is not closing fully. Allowing warm air into freezer and it ices up
    Try a bungee cord across door to hold closed (after you defrost)
    Most seals are not replaceable........mfg. wants you to replace doors
    What BRAND/MODEL of fridge.
    Sometimes you can reset the seals.
    Place a ball of cotton under seal in each corner.
    Then warm seal using hair dryer/blower
    When seal is warm close door and let seal cool off
    After cooled down remove balls of cotton in corners.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
