jornvango
Aug 18, 2026Explorer II
Like small fans? Point in which direction?
- StirCrazyAug 18, 2026Moderator
you want to put them at the top vent, pulling air up, don't force it in from the bottom. also make sure there is not to much space between the fins on the back of the fridge and the space wall. this is the most common instalation mistake which allows aire to go around the fins instead of through them. Idealy what you are trying to do is get more air movments through the fins on the back of the fridge
- LwiddisAug 18, 2026Navigator
Outside…up…the direction heat wants to travel. Inside I use a fridge box fan about 3’x3’.
Related Content
- Feb 01, 2026Community Alumni
