jornvango
Aug 18, 2026Explorer II
Thanks! Current outside temperature is 99 F, the fridge is at 71 F. Will adding fans potentially fix that as it's a long way down from 71 F to 34 F or something close ...
- LwiddisAug 19, 2026Navigator
71F is in the BIG danger zone!
- jetboatrich727Aug 19, 2026Explorer III
71 seems very warm, in my opinion fans won't fix that, did you adjust the temp on the slider, maybe bumped it?
- jornvangoAug 19, 2026Explorer II
I tried moving the slider up (thermistor sensor), but no improvement.
Then I tried unplugging the slider cable from the control board in the back as I read that that would force the fridge to run at full power, but no improvement either.
Overnight, when the outside temperature goes down into the 70s, the fridge goes down to around 60 F, so not good, even overnight.
Definitely not working........
Related Content
- Feb 01, 2026Community Alumni
