jornvango
Aug 19, 2026Explorer II
I tested the thermistor and it reads 5,220 ohms at room temperature (80F) which seems to be OK.
AI says:
When a Dometic DM2652 thermistor is unplugged, the control board defaults to maximum cooling (running continuously). If the fridge still does not cool at all, the issue is not the thermistor, but rather a lack of power, a failed main control board, or a blocked/dead cooling unit.
So seeing that the freezer is working, I can assume the fridge has power and the cooling unit is working, so that leaves the main control board? Is that a correct assumption based on the above and how does one test a main control board?
jetboatrich727
Aug 19, 2026Explorer III
Did you look at the manual and get any codes?
- jetboatrich727Aug 20, 2026Explorer III
Curious on this as well
Related Content
- Feb 01, 2026Community Alumni
