Old-Biscuit
Sep 18, 2020Explorer III
You posted "....2020 travel trailer parked at a site for a few weeks."
During that few weeks was trailer plugged into AC Shore power and had good 12VDC Power?
Was fridge being operated in 'AUTO' mode?
Norcold N8X......part of the Polar Series
BOS (Backup Operating System) allows fridge to continue to cool if temp sensing is lost. But it uses a 'timed base' heating cycle vs a 'temperature based' cycle
Time based can be changed by increasing (colder) or decreasing (less colder) Temp Set point
Bad thermistor/unplugged thermistor results in BOS but fridge should have still being functioning
External Thermostat/Fan is 'OPTIONAL'
It is a must need if fridge is in a slideout
It is a nice to have if fridge uses a roof vent
Thermostat is attached to condenser fin...closes at 130*F FIN Temp (starts fan) and opens at 115*F FIN Temp (stops fan)
In order to see if you have Fan Option check wiring on lower circuit board P1 8 pin connector (bottom of board)
Pin #1 ----- 12VDC Ground
Pin #6 ----- 12VDC POS
*Pin Numbers go right to left
No Error Code?
W/O it flashing any codes it is hard to guess what is going on
Could be circuit board, could be upper display, could be harness between the two etc
Troubleshooting starts on pg 29 thru 34 for 'X' models
Go thru those checks and see if something turns up
Norcold 7/8 Polar Series
No Error Code?
