dougrainer
May 08, 2016Nomad
grizzzman wrote:Chris Bryant wrote:
The top condensor fins are the most critical. The more liquid ammonia you can condense out the more cooling you will have. The absorber coils do reject some heat, but that is not their real function.
The unit should be baffled so that all of the air must pass over the condensor.
Chris what is you're opinion on the ADP system?
The ARP system is a GOOD addition to any RV refer. It keeps you from damaging when run either off level or if you get a ventilation blockage. Doug
