Boatycall
Sep 17, 2015Explorer
enblethen wrote:
No thermal couple. Should have a flame sensor.
I would check to make sure the probe is directly in the flame.
This should help.
Dometic service manual from Bryant RV
THANK YOU very much!! That had exactly what I needed. For reference in case anyone needs this same info later, here's what the service manual said--
To check the flame sense circuit of the lower circuit board, operate the refrigerator on GAS and measure the millivolts between J4 (NEGATIVE) terminal and J10 (POSITIVE) connection from the thermocouple. The thermocouple should produce 20 millivolts DC minimum.
Anything less than 20 millivolts will cause erratic gas operation. The meter should read between 25 to 35 millivolts with the gas flame burning.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
Related Content
- Feb 01, 2026Community Alumni
