ctgsocal's avatar
ctgsocal
Fridge runs on AC but not LP
It is an RM2607 about 23 years old. Runs fine on AC but not on gas. Has the Dinosaur Electronics control board. Cleaned out the orifice soaking it in alcohol. Cleaned the burner tube. Ignitor works. Replaced the thermocouple. Could be the gas valve solenoid does is not opening. Is there a way to test the solenoid to see if it has failed? Anything else that I can troubleshoot? Thanks in advance.
  • Does the gas stove work?
    How about the gas furnace?
    Does Propane tank have ga in it?
    Propane valve open?
    Some have a electronic Emergency shut off valve also. That may not have turned on.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
